Festool PS 420 EBQ-Plus Jigsaw
- Accurate and precise vertical cuts with blade guide system
- Powerful cutting stroke, compact and light in weight
- Fast, tool-free changing of saw blades, tables and baseplates
- Ergonomic and softgrip design makes for simple handling
- Re-designed blade guide system
- Changeable base plate
- Electronic switch on both sides, reachable in every grip position
- An exceptional pendulum jigsaw with an unbeatable profile- cutting capacity
- Supplied with, 2 blades, splinter guard and base runner
- Systainer SYS3 M 137
The newest jigsaw in the Festool range is the CARVEX PS 420 with a new blade guide system and more powerful motor than the PS400 model. The blade can be guided in three ways with a new lower guide that can be adjusted to 'kiss' the blade. A powerful hammer guide contained within the body of the machine ensures accuracy. Combined with a choice of four pendulum stroke actions and speed selection, you can be assured of a smooth, precise cutting action, designed to work hard in a range of materials with the right choice of blade. The powerful cutting stroke is driven from the Festool EC-TEC brushless motor, it is compact in design and one of the lightest on the market at only 1.9kg. An adjustable strobe light is also a great feature. Effective dust extraction draws dust away from the cutline via connection to a dust extractor from the outlet in the base. The Festool unique plug-it cable can be turned upwards in more confined spaces and is easily unplugged for tool change or storage. The body grip design on/off switching can be worked from either side of the body for dual use. Supplied with a standard removable base that can be replaced with a choice of either a tilting 0- 45° angled base or a base adaptor that allows you to connect guide rails or circular guide; a quick lock ensures no tools are required for base or blade changing. Angle base and adaptor bases are optional accessories.
This ‘Plus’ version supplied with 2 saw blades, splinter guard, base runner for delicate surfaces LAS-STF and Systainer SYS3 M 137.
