Festool Diamond Discs for RENOFIX RG 130 Diamond Grinder
102418
102418
- Red – Abrasive: for resurfacing green concrete, sandstone, soft plaster etc., grinding cement screed for a smooth finish. Removing adhesive on screed, sand-lime bricks and aerated concrete.
When fitted to the Festool RG 130-E these diamond discs rapidly remove material from a wide variety of hard surfaces. The discs are 130mm in diameter, the diamond impregnated segments work in much the same way as a diamond cutting disc; in this case working on the flat effectively grinding the surface away.
