Festool S 75/1.4 K/5 Jigsaw Blades Fine Wood & Plastic (Pkt 5)
- Fine-toothed curved blade for splinter-free, fine cuts in wood and plastic
- Conically ground teeth for clean cuts, to cut curves
- Blade length 75mm
- Max. material thickness 30mm
- Pack of 5
Fine-toothed curved blade for splinter-free, fine cuts in wood and plastic. Conically ground teeth for clean cuts, to cut curves. Blade length 75mm.
Blade Type | HCS, Ground |
EAN Barcode | 4014549140406 |
Jigsaw Blade Length | 75 mm |
Jigsaw Blade Type | Curve Cutting |
Manufacturer Part Number | 486564 |
Max Cutting Depth | 30 mm |
Model | S 50/1.4 K/5 |
Pack Quantity | 5 |
Tooth Pitch \ tpi | 1.40 mm \ 18 tpi |
- Standard Delivery* - £4
