Festool Saphir Abrasive Sanding Disc 150mm (Pkt 25) - 24g
103601
103601
- Ideal abrasive for extreme applications
- Long lasting, highly durable aluminium oxide abrasive
- Heavy-duty, tear-resistant cloth backing
- Jetstream hole pattern for efficient dust removal
- Use for sanding wood, paint, plastics, fibreglass, composites, concrete
- Packs of 25, 150mm diameter discs
Festool Saphir abrasives consist of durable aluminium oxide abrasive bonded onto a tear-resistant, heavy-duty cloth backing. These 150mm diameter discs are ideal for extreme applications such as heavy-duty sanding of wood, paint, plastics, fibreglass, composites, concrete and steel. Engineered and manufactured to strict FEPA standards, Saphir abrasive guarantees consistent sanding results. The high tech coating provides maximum resistance to clogging, resulting in longer lasting abrasives. The Jetstream hole pattern delivers highly efficient dust removal, adding to abrasive life.
