Festool Saw Blades For ISC240EB Saw (DSB/G)
- Blades for the Festool insulation cutter ISC 240 EB
- To fit cutting set SG-240/G-ISC or SG-350/G-ISC
- Either 240mm or 350mm long
Customers Also Bought
Replacement blades for the Festool insulation cutter ISC 240 EB, fitting the cutting set SG-240/G-ISC or SG-350/G-ISC (choose correct length) .
These blades are suitable for cutting insulation materials: polyurethane foam PUR and PIR. polystyrene foam and pressure-resistant rock wool and glass wool. (Not suitable for pressure-resistant wood fibre insulating materials.)
- For cutting PUR, PIR and polystyrene foam insulation
- Cuts pressure-resistant rock wool and glass wool
- (Not suitable for pressure-resistant wood fibre insulation)
