£894.96 £745.80
Low stock
- get it tomorrow, Saturday 8th Aug, order within and choose Premium delivery. Delivery info
  • Great saw for timber framing, renovation, roofing and insulation
  • Cutting timber and hard insulation materials up to 200mm
  • Special chainsaw blade gives an accurate precise cut
Customers Also Bought
Total: £905.68
A totally new type of saw for Festool, cutting all standard materials used in timber construction up to 200mm, from wood to hard insulation materials. A great saw for timber framing, renovation, roofing and insulating. Lighter in weight and with a large depth of cut, it can go where a circular saw is unable to go. The special chainsaw blade gives an accurate precise cut especially when used with the optional Festool guide rail system. Optional chains are available. The chain makes a drawing cut for rapid jolt-free operation and is speed adjustable. Efficient electronics give constant power when sawing for a consistent cut. Perfect for deep mitre and compound angles, it has a swivelling range of 0-60° with cut depths of 200mm@90°, 140mm@45° and 100mm@60°. The sword approach can be tilted up to 10° allowing for an even faster drawing cut. The chain is changed using the FastFix quick change system, a wheel then tensions the blade and there is also adjustment on the chain lubrication feed. Fitted with extraction outlet and fixed 7.5m power lead.
PLUS version supplied with universal saw chain, chain oil 250ml, 7.5m cable, Systainer SYS 5 TL.
  • Recommended use with Festool guide rail system
  • Chain makes a drawing cut for rapid jolt-free operation
  • Variable speed and speed maintained under load
  • Deep mitre and compound angles (0-60°)
  • Fast work progress - tilt up to 10°
  • Chain: FastFix change, quick tension and variable lubrication
  • 27mm extraction outlet and 7.5m power cable
  • PLUS version supplied with universal saw chain, chain oil 250ml, 7.5m cable, Systainer SYS 5 TL
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
