£126.86 £105.72
Low stock
- get it Wednesday 5th Aug, order within and choose Premium delivery. Delivery info
  • The easy way to apply wood oil contains, Oil bottle with hand grip
  • Base plate with sponge to evenly distribute oil onto surface
  • Oil flow is simply controlled, sponge absorbs excess oil
Customers Also Bought
Total: £559.72
This is the Festool solution to applying oil in a very controllable way, allowing you to achieve a very clean and even finish. This system uses an oil bottle (that doubles as a handgrip) which simply clicks to a base plate fitted with a safety valve, closing the oil bottle and protecting it from drying out when stored. To apply squeeze the bottle, you control the flow of oil, then distribute evenly using the foam pad, this absorbs any access oil and reapplies it where required. The square pad reaches into corners, it also copes well with edge work, contouring to many profiles. The supplied natural oils are suitable for light and dark woods, covering almost all indoor and outdoor applications, solvent free, sweat and saliva proof (DIN 53 160).
This set contains 3 x 300ml oil in bottles, 1 each; outdoor oil, heavy duty oil and one-step oil, storage tin (for between applications), 5 x StickFix oil sponges (125 x 125mm), 5 x green and 5 x white sanding cloth, 20 x 150mm sanding discs (10 x Rubin 180g and 10 x Brilliant2 240g), supplied in a SYS3 T-LOC systainer case.
  • 3 x 300ml natural oils; Heavy duty and One step oil and wax
  • Outdoor - exterior oil with protection against UV and fungal growth
  • Storage tin for storage of oil in base, square 115mm base plate
  • 5 x oil sponges, 5 x green and 5 x white sanding cloth
  • 20 x 150mm sanding discs (Rubin 180g and Brilliant2 240g)
  • T-LOC systainer case SYS3
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
