Festool T18+3 Li Cordless Drill 18V (Body Only)
- Ultra-compact, high precision 18V drill driver
- EC-TEC® brushless, wear resistant motor, optimum torque adjustment
- Full electronic control with 25 torque settings allows for total precision
Customers Also Bought
This T18+3 is supplied as a Basic, body only version with T-Loc Systainer case, CENTROTEC chuck, CENTROTEC bit holder, PZ2 bit and 13mm FastFix chuck with yellow and green plastic containers.
Compact in design and with high precision, the T18+3 drill is fitted with the Festool specially developed wear-resistant EC-TEC® motor and a patented compact gear mechanism, giving maximum transfer of force with integrated torque cut-out to protect it from overload. It is electronically controlled with 25 torque settings in each mode for total precision. It can be fitted with the Festool range of 18V batteries for maximum energy at a low weight. The drill is fitted with a FastFix precision system which holds either the supplied 13mm keyless chuck or CENTROTEC® rapid tool change system (also any other Festool FastFix tool holders), giving the working bit true running precision.
3 year Festool Service All-Inclusive warranty on registration.
- Switch from drill to screwdriver mode without torque change
- Motor and battery protection, charge indicator
- Quick change CENTROTEC chuck and bit holder
- PZ2 screwdriver bit, yellow and green part containers
- T-LOC SYS 2 SYSTAINER case
- Supplied as body only without battery or charger
