Festool TPC 18/4 I-Basic Cordless QUADRILL 18V (Body Only)
- 4-gears all the power, torque, versatility and potential
- Added safety; intelligent anti kickback stop for protection
- FastFix interface for rapid changing of accessories
- EC-TEC motor no-maintenance, long service life
- All the torque and speed needed for any job
Festool claims this is the best drill they have ever built. Taking a look at the specifications and capabilities it’s hard to refute the claim. With four gears, the TPC 18/4 has all the power, torque, versatility and potential you need.
The QUADRIVE gearbox offers a choice of four gears to cover any working situation. Be it screwdriving with 75Nm torque in first gear or precise drilling at 3,600 rpm in fourth gear
1st gear: Tighten and drive demanding screws up to 10mm.
2nd gear: Quick screwdriving of screws up to 8 x 300mm.
3rd gear: Powerful drilling with auger bits of up to 20mm.
4th gear: Drilling with medium and small bits up to 35mm.
The brushless EC-TEC motor is extremely durable and converts the energy from the battery into power with virtually no loss. An intelligent kickback stop protects your wrist if the drill suddenly becomes caught or jammed, greatly improving your safety.
The FastFix interface allows rapid changing of any of the optional accessories such as angle drilling attachment, offset screwdriver etc. The large number of attachments available make the TPC the most versatile combi drill in its class.
Supplied with auxiliary handle, depth stop, fastfix keyless chuck, fastfix Centrotec bit holder, 2PZ Centrotec bit, belt clip and Systainer SYS3 M 187 case.
Note: This is a body only tool supplied without a battery or charger
