Festool TS 55-FEBQ Plus Plunge Saw & 1,400mm Guide Rail
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses and LLPs on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- A perfect cut with maximum cutting performance
- Accurate plunge cutting saw for splinter free cuts
- 1.8mm thin kerf blade for fast cutting
The combination of a Festool circular saw and the Festool Guide Rail creates a superb system for cutting sheet materials. Festool’s TS 55 saw has a reputation for absolute precision cuts, maximum power and extreme durability.
The TS 55-FEBQ takes a 1.8mm kerf blade. The narrow kerf means it removes much less material, allowing the TS 55-FEBQ to cut at up to twice the speed of previous models. Coupled with a 1,400mm guide rail it’s unbeatable; guaranteeing a perfect cut with maximum cutting performance everytime. The angle adjustment from -1° to 47° allows a slight undercut for perfect butt joints. In addition, the cut line remains the same no matter what the cutting angle.
Supplied with 1,400mm guides rail, 42 tooth thin kerf blade and Systainer SYS3 M 337 carry case.
N.B 230V version is known as model TS 55-FEBQ.
In order to take advantage of the Festool Warranty All-Inclusive, you will need to create a MyFestool account and register your tool within 30 days of purchase.
Benefits
- Includes 36-month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft*
- Original parts guaranteed
- 14-day money back*
All Warranty claims are handled directly with manufacturer please refer to the warranty information supplied on registration for correct procedure.
Warranty issues outside of the UK - Please refer to the warranty in the home country and if a tool has to be returned to UK be aware that all postage costs would need to be arranged and paid by the customer.
Axminster Tools cannot register a Festool tool on a customer's behalf.
NB: For more information and *full terms and conditions visit the Service section of the Festool website.
Find out more| Bevel Angle Range | -1° to +47° |
| Blade Diameter | 160 mm |
| Bore Size | 20 mm |
| Corded or Cordless | Corded |
| Dust Extraction | 27 mm / 36 mm Outlet |
| EAN Barcode | 5052511125975 |
| Kerf | 1.8 mm |
| Manufacturer Part Number | 230V - 577012 |
| Max Depth of Cut @ 45º | 43 mm |
| Max Depth of Cut @ 90º | 55 mm |
| Model | TS 55 FEBQ-Plus-FS |
| Motor Power | 1,200 W |
| Nett Weight | 4.5 kg |
| Plug Fitted | UK 3 pin plug |
| Saw Blade Speed | 2,000 - 5,800 rpm |
| Sound Power Level LwA [Uncertainty K] | 101 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 90 dB(A) [3.0 dB] |
| Spindle Lock | Standard Feature |
| Voltage | 230 V |
- Standard Delivery* - Free
