Festool TS 55-FEBQ Plus Plunge Saw
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Accurate plunge cutting saw for splinter free cuts
- 1.8mm thin kerf blade for fast cutting
- Fully compatible with Festool FS guide rail system
Festool TCT Saw Blade Thin Kerf Laminate - 160mm x 1.8mm x 20mm 52TFrom £88.78 £73.98
Festool’s TS 55 saws have a reputation for absolute precision cuts, maximum power and extreme durability. This latest incarnation is no exception. The TS 55-FEBQ takes a 1.8mm kerf blade. The narrow kerf means it removes much less material, allowing the TS 55-FEBQ to cut at up to twice the speed of previous models. The new generation of cutting blades guarantees perfect cutting quality with maximum cutting performance.
A detachable splinter guard in front of the blade, gives a virtually splinter-free finish on both sides of the workpiece. Behind the blade a guide wedge acts as a riving knife and aids positioning the saw in an existing cut. The angle adjustment from -1° to 47° allows a slight undercut for perfect butt joints. In addition, the cut line remains the same no matter what the cutting angle. With the TS 55-FEBQ maximum cutting performance meets perfect cutting quality.
Optional guide rails, a wide variety of thin 1.8mm kerf saw blades and connection to an extraction system, form a first-class sawing system.
Supplied with 42 tooth thin kerf blade and Systainer SYS3 M 337 carry case.
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft
- Original parts guaranteed
- 14 day money back
Bevel Angle Range | -1° to +47° |
Blade Diameter | 160 mm |
Bore Size | 20 mm |
Corded or Cordless | Corded |
Dust Extraction | 27 mm / 36 mm Outlet |
EAN Barcode | 4014549373439 |
Manufacturer Part Number | 230V - 576706, 110V - 576707 |
Max Depth of Cut @ 45º | 43 mm |
Max Depth of Cut @ 90º | 55 mm |
Model | TS 55-FEBQ |
Motor Power | 1,200 W |
Nett Weight | 4.5 kg |
Rating | Trade/Professional |
Saw Blade Speed | 2,000 - 5,800 rpm |
Sound Power Level LwA [Uncertainty K] | 101 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 90 dB(A) [3.0 dB] |
Spindle Lock | Standard Feature |
Voltage | 230 V |
