Festool TS 55R EBQ-Plus-FS Plunge Saw, 2 x 1,400mm Rails & Accessories
From £629.96 £524.97
  • TS55R Saw with 2 x 1,400mm guide rails, 2 x rail connectors, pair of screw clamps and guide rail bag
  • Accurate splinter-free plunge cuts
  • Flush housing for cutting standard 12mm distance, bevel cuts -1° - 47°
Customers Also Bought
This package contains a TS55R saw, 2 x 1,400mm guide rails, 2 x rail connectors, pair of screw clamps and padded rail bag
The Festool TS55R is a very fast and efficient plunge saw with many features. When used with Festool's guide rail system you can process sheet materials of all types with ease and accuracy. The rail in many cases does not need to be clamped to the work. The saw has a 1,200W soft start motor with full electronic control to keep speed constant and monitor the motor allowing the optimum cutting speed for the material being cut, regardless of load. The clear window on the side allows you to see the blade, and markers indicate front and rear cutting points of blade at full depth - useful when cutting out apertures with the guide rail. The cutline stays constant in relation to the base, regardless of blade angle. This saw has the ability to cut a standard 12mm against a wall thanks to its flush housing. There is a fine adjuster for the plunge and the blade now has an undercut of -1° to 47° for even greater accuracy and an adjustable viewing window ensures you can see the saw blade during use. The spring-loaded pivoting plunge action combines with a super-fast blade brake to give fast, accurate and, above all, safe cutting performance. Other features include a rotating dust outlet for the most convenient position and FastFix blade changing system. The guide rails have a splinter guard, underside cushion strip to grip work and a slideway top surface lining.
Supplied with 2 x 1,400mm guide rails with anti-splinter guard, 2 x rail connectors, 2 x screw clamps and rail bag. The saw has a 48T TCT blade and anti-splinter device and is supplied in a T-LOC Systainer case.
  • 55mm depth of cut with very accurate depth setting scale
  • Double pinion tilting action with accurate scale
  • Anti-splinter shoe fits to saw for splinter-free working
  • FastFix saw blade change system
  • Electronic speed control with feedback for constant speed
  • Complete with Plugit® mains cable system
  • Multi-position dust extraction outlet
  • 1400mm guide rails with splinter guard strip, top slide way and underside grip
  • Electronic brake (230V version only)
  • 3 year warranty when registered (excludes cutting blade)
    Privacy Policy & Cookies
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA sale tagBusiness ServicesA building with a door at the frontClick & CollectA shopping bag with a handleThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMenuThree Horizontal lines stacked on top of each otherPayPalPayPal payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTickA tick symbolDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolYouTubeThe logo for YouTube
