Festool TS 60 KEBQ-Plus-FS Plunge Saw & 1,400mm Guide Rail 230V
720834
From £784.98 £654.15
7 Reviews
Dispatching Soon
- Email me when available
Delivery
Free Standard Delivery*.
Dispatch estimate is currently unavailable.
  • Superb combination for accurate spot-on cutting
  • Maximum depth of cut of 57mm with rail
  • Guide rail features PTFE strips for smooth operation
  • Thin kerf blade ensures quick results
  • Highly effective dust extraction with suitable extractor
  • Saw features a compact and powerful EC-TEC motor
  • Anti kickback system, protects from injury and damage
Festool TS 60 KEBQ-Plus Plunge Saw 230V
Making kickbacks a thing of the past
Achieve an excellent cut of depth with less maintenance than before, with its powerful brushless motor. Feel secure in your tool, with its unique anti-kickback system that ensures protection for you and your workpiece.
Easier to use
Setting new standards, the latest brushless EC-TEC motor is compact and essentially maintenance-free. Complete tasks quickly and with less effort.
Improved safety
Taking safety to a whole new level, the TS 60 ensures that you and your workpiece remain protected when sawing or plunge-cutting, with its unique KickbackStop system.
Versatile
Festool’s most versatile saw, interchange with a 1400 guide rail or cross-cutting rail for maximum adaptability. Achieve premium results even when working with mitre cuts and solid worktops.
Angles
A full range of positions are available, including undercuts, from -1 to 47 degrees. You can be sure you are making accurate cuts every time, even on an angle.
Improved performance
The high-speed motor of 6,800rpm ensures ideal machining, with an effortless feed rate. As a result, the thin kerf blade provides the best cutting quality.
Greater cutting depth
Dive deeper and produce premium cuts with ease, with it’s its extremely powerful 60mm cutting depth,
Added stability and innovation
Combine the saw with the guide rail for superb cutting sheet material. The saw glides smoothly along the rail with its two PTFE strips and neoprene strips, to prevent slippage and splintering.
  1. Festool TS 60 KEBQ-Plus-FS Plunge Saw & 1,400mm Guide Rail 230V
Total:
£1,334.92 £1,112.43
The combination of Festool’s TS 60 plunge saw and the Festool 1,400mm Guide Rail creates a superb system for cutting sheet material with spot-on accuracy.
The TS 60 offers a massive maximum depth of cut of 62mm, even when used with the guide rail, you still have 57mm. A unique anti kickback system, protects you from injury and damage to your work. A transparent sliding viewing window and additional markings provide a view of the blade’s start and end point, prior to making a plunge cut. Dust extraction is highly effective when connected to a suitable extractor. With the latest generation brushless EC-TEC motor, the TS 60 is compact, virtually maintenance-free and powerful. Fitted with a thin kerf saw blade, the high speed 6,800 rpm EC-TEC motor ensures quick results.
The guide rail has two PTFE strips to allow the saw tool to glide smoothly on the rail. On the underside of the rail there are two neoprene strips, which prevent slippage. There is also a special rubber strip on the underside which is used to minimise splintering on the top surface.
The TS 60 offers a massive maximum depth of cut of 62mm, even when used with the guide rail, you still have 57mm. Supplied with a 1,400mm guide rail the TS60 can also be attached to the optional cross cut rails.
Benefits
  • Includes 36 month machine guarantee
  • Full repair, free of charge
  • Replaced in the event of theft
  • Original parts guaranteed
  • 14 day money back
5.00 7
