Festool TS 75 EBQ-Plus Plunge Saw
- Precise with impressive 75mm depth of cut
- Powerful, MMC electronics adapt the speed to suit the material being cut
- Exact depth setting, 0-47° angle cuts to millimetre accuracy
- Side splinter guard for a clean cut both sides
- Triple bearing of the motor, blade brake
- Sliding clutch for extra safety, FastFix saw blade system
- Plug it mains cable and rotating dust connector
- 36 tooth TCT blade, kickback stop, splinter guard and systainer case
- Easy connection to Festool guide rail system
Precision is the key as with any Festool tool and, with an impressive 75mm depth of cut, this TS 75 plunge saw has the power and accuracy to deliver the most accurate cut. Being the larger brother of the TS 55, features include exact depth setting with a notched depth stop (accurate to the millimetre), a side splinter guard, a sliding clutch for extra safety if the blade jams, a quick brake, FastFix saw blade system, plug it mains cable and rotating dust connector. MMC electronics adapt the speed to suit the material being cut and a triple bearing of the motor results in smooth running and long service life. The saw cuts at angles 0-47° and can be easily connected to the Festool guide rail system for even greater versatility. Supplied with a 36 tooth TCT blade, kickback stop and splinter guard in a SYS 5 TL Systainer case.
