Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Festool TSC55 LI 5.2 REBI-PLUS Saw Bluetooth & FS1400 Guide Rail 18V
Code: 720643
  • Festool TSC 55 LI 5.2 REBI-PLUS 18V Circular Saw
  • Cuts boards and panels up to 305mm x 88mm
  • Bluetooth batteries for auto switching of compatible extractor
  • Runs on single battery (18V) for lighter weight
  • Use twin battery option (36V) for heavy cuts
  • Spring-loaded, smooth, pivoting plunge action
  • Brushless EC-TECH® motor, high efficiency, long service life
  • Bevel cutting range -1° to +47°
  • Supplied with 2 x BP 18 Li 5.2 ASI battery packs, SCA 8 rapid charger, fine tooth saw blade HW W48, splinter-guard, Flag window; vision panel, chip collection bag and a SYSTAINER SYS 5 T-LOC case
  • Festool FS1400 Guide Rail
  • Converts HKC saw into a system for cutting sheet materials
  • Two embedded PTFE strips help saw glide
  • Two underside neoprene strips to reduce slippage
  • Splinter strip minimises splintering
  • Show More
Free Extras
Free Festool 18V 5.2Ah AIRSTREAM Bluetooth Battery worth over £100!! (Offer Restricted to UK only)
£824.95 (£687.46 Ex. VAT)
Low stock - get it Tuesday 2nd Jun, order within and choose Premium delivery
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - free
  • Premium UK (next day) - from £6
  • International - unavailable
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
  • Festool TSC55 LI 5.2 REBI-PLUS Saw Bluetooth & FS1400 Guide Rail 18V
  • Festool Carrying Bag for Rail with Shoulder Strap
  • Festool PSBC 420 Li Cordless Jigsaw 18V (Body Only)
  • Festool Extractor Cleaning Set D27/36 K-RS Plus
Total: £1,250.47
Description
In Detail
Festool 3 Year Warranty (Registration Required)
Package deal comprises a Festool TSC 55 LI 5.2 REBI-PLUS 18V Circular Saw with Bluetooth batteries and an FS1400 1,400mm Guide Rail
The batteries include the latest Bluetooth technology. They can communicate with a Festool mobile dust extractor fitted with a Bluetooth receiver offering the unique advantage of auto switching with a cordless tool
With the TSC 55, you get the benefit of cordless freedom. The maintenance-free EC-TEC® brushless motor ensures consistent high performance. The saw can run off a single 18V battery for general work, or two batteries giving 36V maximum power for heavy cuts. The saw has a spring-loaded, pivoting plunge action that combines with a super-fast blade brake to give accurate and, above all, safe cutting performance. A slide and lock guide and clear scale on the top of the blade guard make setting the depth of cut a simple operation. The cutline stays constant in relation to the base, regardless of blade angle. The bevel cutting range is -1° to 47°.
Supplied with two BP 18 Li 5.2 ASI battery packs, SCA 8 rapid charger, fine tooth saw blade HW W48, splinter-guard, Flag window; vision panel, and chip collection bag, all packed in a SYSTAINER SYS 5 T-LOC case.
Registering the saw for an extended warranty includes a 3-year warranty on the battery.
FS1400 Guide Rail
The combination of the HKC 55 the FS1400 Guide Rail creates a superb system for cutting sheet materials. The guide rail has two PTFE strips embedded into it allowing the tool to glide smoothly on the rail. On the underside of the rail, there are two neoprene strips, which hug the surface of the material, reducing slippage. There is also a special rubber strip on the underside, which minimises splintering on the top surface of the board. Length 1,400mm.
Specification
Specification
Batteries Included 2
Battery Capacity 5.2 Ah
Battery Type Li-ion
Battery Voltage 18 V
Blade Diameter 160 mm
Bore Size 30 mm
Charge Time 33 minutes
Corded or Cordless Cordless
Model TSC55 LI 5.2 REBI-PLUS
Nett Weight 5.3 kg with 2 x 18V
Rating Industrial
Sound Power Level [Uncertainty K] 99.5 dB(A) [3.0 dB]
Sound Pressure Level [Uncertainty K] 88.5 dB(A) [3.0 dB]
Spindle Lock Standard Feature
Vibration Cutting Wood [Uncertainty K] 2.8 m/s² [1.5 m/s²]
Max Depth of Cut @ 45º 43 mm
Max Depth of Cut @ 90º 55 mm
Saw Blade Speed 2,650 - 3,800 rpm (with 1 x 18V batt) 2,650 - 5,200 rpm (with 2 x 18V batt)
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
