Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Festool Vacuum Clamping System
Code: 703863
  • 100W pump unit is built into its own Systainer box
  • So quiet you will hardly know its running
  • 215mm suction base able to rotate through 360° and tilt though 90°
  • Holding force at level 90kg
  • Holding force at 90° of tilt 55kg
  • Full of innovation easy to use
  • Portable at just over 16kg complete
  • Show More
£1,039.96 (£866.63 Ex. VAT)
Out of stock - dispatch estimate is within 2 weeks.
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Festool 3 Year Warranty (Registration Required)
This Festool product is full of innovation, easy to use, unrivalled for build quality and has that "must have" appeal. Easily portable at just over 16kg complete, and comprising 2 parts, the 100W pump unit is built into its own Systainer box with external connections for power and vacuum hose, together with the operating switch and vacuum gauge. At 68dB(A) it's so quiet you will hardly know it's running. A second box houses the vacuum clamp unit plus hoses and a foot pedal control. The clamp kit has a 215mm suction base as standard which is able to rotate through 360° and tilt though 90°. The whole clamping assembly is based on a die cast alloy housing, and cleverly, it can clamp itself to your work table! The suction pad has a central push valve to activate the suction automatically when you place the workpiece onto the pad, the suction is then released by the foot pedal control. With up to 90kg of suction force your work is really clamped. For large work an extra clamping kit can be purchased, complete with all connectors etc, and in its own Systainer box. This will enable doors and other large items to be held. These clamps will hold wood, plastics, MDF, glass and many other materials. You can then sand, plane, rout, machine, assemble and finish many types of work in safety and in a manner that will not damage or contaminate the work. If you are a joiner, boat builder, musical instrument or cabinet maker, or wish to display your work at an exhibition, this system will provide a long term solution to many work holding problems.
Information Downloads
Specification
Specification
Model Sys 1
Nett Weight 16.3 kg
Pad Size 215 mm
Sound Power Level [Uncertainty K] 68 dB(A) [3.0 dB]
Sound Pressure Level [Uncertainty K] 55 dB(A) [3.0 dB]
Suction 15.0 kPa
Voltage 230 V
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
