FISCH Multi-Function Wave Cutter Forstner Set
104268
From £174.98 £145.82
5 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Thursday 22nd May
  • 'Wave' style cutting edge for clean flat-bottomed holes
  • Exchangeable tip: centring point or pilot drill
  • Precise drilling even at extreme angles
  • Forstner design allows boring partial holes on edges
  • Quick connection extension, 100% true running
  • 15, 20, 25, 30 and 35mm bits, 93mm extension, 2 centre points, 2 x 4mm pilot drill and a dismantling tool
  • Made in Austria
  1. FISCH Multi-Function Wave Cutter Forstner Set
Total:
£321.72 £268.10
This multi-function Wave Cutter Forstner bit combines the many benefits of Fisch’s patented Forstner bit with the benefits of a wood twist drill with an extra-long centring tip. These bits offer precise drilling at extreme angles.
FISCH forge their Wave Cutter Forstner bits from a single billet, before being CNC grinded and then hardened. Accuracy and sharpness are of the highest level. The unique serrated 'Wave' edge produces extremely clean entry holes, allows faster cutting speeds and requires less effort to bore each flat-bottomed hole.
These bits feature an exchangeable centring tip, giving you a choice of using either a standard centre point or a 4mm pilot drill.
The shank has 3 flats for secure chucking in a 3-jaw chuck, and easy installation of extensions. Quick connection extensions automatically lock, maintaining 100% true running accuracy without the need for grub screws etc.
This boxed set comprises 15, 20, 25, 30 and 35mm bits, a 93mm extension, 2 centring tips, 2 x 4mm pilot drill bits and a dismantling tool. Made in Austria.
5.00 5
