FISCH Beam Drills
FISCH Beam Drills
- Milled from solid stock, deep cut flutes give fast waste removal
- Intended for drilling through beams, gate posts etc
- Wide, ground lands keep the drill straight and true
- Overall length 250mm, working 200mm
- Made in Austria
FISCH have produced an industrial quality brad point (lip and Spur) drill milled from solid stock with a centre point for location and a pair of cutting spurs. The leads ensure accuracy and the deep cut flutes give fast waste removal. Intended for drilling through beams, gate posts and so on, but also most useful when drilling deep holes on the lathe. Length 250mm, spiral length 200mm. N.B. The 12mm has a 10mm diameter shank and a reduced shank length of 30mm. Made in Austria.
