FISCH HSS Brad Point Drill Bit
- Extremely resistant: high quality HSS hardened to 62 HRC
- Ground centre point and spurs for precise positioning and clean cut
- Choose from sizes from 3mm to 8mm
- Smooth chip ejection, smooth, ground spiral
- Suitable for drilling in soft and hard wood, glue-laminated boards, MDF, plastic and acrylic glass
FISCH 25 Piece HSS Brad Point Drill Bit SetSpecial Price £71.99 £59.99 was £79.98 £66.65 Save £7.99 £6.66
These HSS drill bits from FISCH® are suitable for drilling into hard and soft wood, MDF and other manufactured boards. They have a precision ground point with twin cutting spurs for precise positioning and a clean cut. Made of very resistant, high speed steel to EN ISO 4957 with a hardness of approximately 62 HRC, these drills give you very good, precise results. Their cylindrical shanks allow their use in all common battery operated and hand-held drilling machines as well as in vertical and bench drilling machines.
Choose from 8 different sizes, from 3mm to 8mm in 0.5mm steps.
Model | 013G Series |
