Rather than a solid centre point, these bits feature a replaceable centring tip (an exchangeable 4mm pilot drill is available). These Forstner bits cut particularly easily and produce exact tear-free, holes with smooth walls in softwood and hardwood. FISCH forge their multi-functional bits from a single billet, before being CNC ground and then hardened. Accuracy and sharpness are of the highest level. The unique serrated 'Wave' edge produces extremely clean entry holes, allows faster cutting speeds and requires less effort to bore each hole. The shank has 3 flats for secure chucking in a 3-jaw chuck. Spare drill bits are available as are centre tips for drilling blind or straight through holes. These bits are 90mm long overall excluding the pilot drill.
For precise inclined drilling even at extreme angles
Centre point acts as pilot for precise positioning
Easy placement on marked entry point, no guessing
'Wave' style cutting edge for clean flat-bottomed holes
