Fiskars Norden N7 Chopping Axe 800g (1.7 lb)
Axminster Professional Combination Square Metric 300mmSpecial Price ÂŁ14.98 ÂŁ12.48 was ÂŁ18.88 ÂŁ15.73 Save ÂŁ3.90 ÂŁ3.25
Axminster Professional Forged Flat Bar Clamp 200 x 80mmSpecial Price ÂŁ11.68 ÂŁ9.73 was ÂŁ15.58 ÂŁ12.98 Save ÂŁ3.90 ÂŁ3.25
WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)Special Price ÂŁ24.98 ÂŁ20.82 was ÂŁ29.98 ÂŁ24.98 Save ÂŁ5.00 ÂŁ4.17
The Fiskars Norden N7 Chopping Axe has a small, compact design. Ideal for limbing, chopping and kindling. Fitted with a high-quality hickory wood handle with virtually unbreakable FiberComp™ overstrike protection. Carbon steel blade with a precision ground, ultra-sharp cutting edge that stays sharp. The antifriction coating prevents the blade from getting stuck and protects against rust and dirt. The perfect companion for camping, hiking and other outdoor activities. Protective blade cover included. Made in Finland.
Specification:
Length: 172mm
Weight: 800g (1.7 lb)
EAN Barcode | 6411501701121 |
- Standard Delivery* - Free
*UK Mainland only. Order before 3pm for Next Day Delivery. Additional charges may apply for remote or offshore areas.
