The PowerGear™ Aviation Snips Right Cut 250mm (10in) are designed for precision and ease of use. They feature forged, heat-treated steel blades for durability and sharpness. The PowerGear™ technology provides leverage-enhancing gears that give you over 40% more power, especially during the toughest part of the cut. The blade tangs extend to the handles for improved strength and stability. ~ The ergonomic handle, with SoftGrip and strategic texturing, ensures added comfort and control. The EasyAction™ feature automatically opens the handle to help reduce hand fatigue. These snips are ideal for cutting a variety of heavy-duty materials, including sheet metal, ductwork, drywall corners, metal studs, siding, soffit, fascia, drip edge, gutters, and more. Length: 250mm (10in) Cut Length: 25.4mm Cutting Capacity: Cuts up to 16-gauge cold-rolled steel (1.518mm) or 20-gauge stainless steel (0.9525mm)
Fiskars
Fiskars PowerGear™ Aviation Snips Right Cut 250mm
| EAN Barcode | 6411501701268 |
