Z-Saw Japanese Fixed Pruning Saw in Sheath - 270mm
- High quality Japanese steel with nickel-plating
- Pistol grip handle with comfortable elastomer grip
- Supplied with protective sheath
- 270mm long replaceable blade
- 0.70mm thick with 2.4mm pitch
This is an ideal saw for pruning small and larger fruit trees or trimming thick branches in unruly hedges. The long blade with its diamond ground teeth cuts like the proverbial hot knife. The saw cuts on both the pull and push stroke, this action produces fast and clean results. When pruning a live tree, a cleanly cut surface will heal much quicker. The saw’s sheath features a belt clip, its design allows you a choice of right or left handed use. The pistol-grip handle has a soft grip for comfort and offers better control. The blade has impulse-hardened teeth and electro-less Ni-P plating for greater wear resistance and increased corrosion protection. The 270mm long blade is replaceable; it is 0.70mm thick with a 2.4mm pitch.
Blade Thickness | 0.70 mm |
EAN Barcode | 5052511094363 |
Length of Blade | 270 mm |
Tooth Pitch \ tpi | 2.40 mm \ 10.5 tpi |
- Standard Delivery* - £1.99
