The CM450 Crucible Furnace is easy to use and perfect for fast melts of aluminium. It can melt up to 2.9kg of aluminium in just 25 minutes and has a temperature range of 950°C to 1,000°C. The unit incorporates the Flamefast tilt and pour principle, which ensures safer metal pouring and extended crucible life. If required, the drum assembly can be detached and carried to the mould using the Combined Lifting and Pouring Tools which are available as optional extras.
This product is classified as an Enquiry product. Enquiry
products require contact with our friendly Business Services team prior to
purchase to understand your requirements. Typically these products have many
customisation options or require product training.
Enquiry products are usually readily available and often despatched directly
from the manufacturer using the best delivery service available. Despatch
times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact customer services for more information.
