Earn extra with DOUBLE Points on all purchases!
Flexcut FR704 4 Piece Super-Wide-Format Palm Set
- Wider chisels for maximum wood removal
- Remove waste wood quickly
- Super sharp, ready to use straight out of the box
- 4 piece set includes:
- FR700 #3 sweep x 22.2 mm (7/8")
- FR701 #6 sweep x 20.6 mm (13/16")
- FR702 #8 sweep x 17 mm (11/16")
- FR703 #9 sweep x 14 mm (9/16")
These wider FR palm tools deliver maximum wood removal with minimum effort. They are designed for carvers wishing to remove waste wood quickly and save roughing-out time. They come super sharp, so you can start carving right away. The blades are high carbon spring steel fitted to polished Ash handles, shaped for comfort and control. The steel has impressive edge retention, with the tip hardened to HRC 59-61. All Flexcut gouges and carving chisels are ready to use straight out of the box. Regular stropping will keep them in top condition.
This four piece set includes:
EAN Barcode | 651646007047 |
Model | FR704 |
Set | 4 Piece |
This product is classified as a Make to Order product.
Delivery time is approximately 6 weeks.
- Standard Delivery* - Free
