Flexcut KN54 Spear Point Small Radius Hook Knife
- Tight radius (10.5mm) knife for carving hollows
- Super sharp, ready to use straight out of pack
- Double edged for left or right handed use
- Full tang design for added strength
- Smooth cherry wood handle
- Blade Length: 48mm, overall length: 165mm
The KN54 Spear Point Small Radius Hook Knife excels when carving deep hollows in spoons or ladles and the like. The deeply swept small radius hook allows you to access hard to reach hollow areas in deeper recesses. The recurved spear point tip gives unmatched versatility for detail carving from all angles. The KN54’s double-edged design means you can use it right or left handed. For added strength, a brass ferrule has been added and the tang extends completely through the handle. The handle is beautifully made of seasoned Cherry wood.
Blade length: 48mm, overall length: 165mm, radius: 10.5mm and double edged.
Blade Shape | Curved Edge Double Sided |
EAN Barcode | 651646500548 |
Model | KN54 |
This product is classified as a Make to Order product.
- Standard Delivery* - Free
