Flexcut KN55 Spear Point Variable Radius Hook Knife
- Variable radius 13mm to 32mm for carving hollows
- Super sharp, ready to use straight out of pack
- Double edged for left or right handed use
- Full tang design for added strength
- Smooth cherry wood handle
- Blade Length: 57mm, overall length: 172mm
Right hand cuts, left hand cuts, pull or push, the KN55 Spear Point Variable Radius Hook Knife makes short work of hollowing a spoon. The gently sweeping hooked blade, with its variable radius helps carve a wide variety of bowl shapes. The spear point tip gets into all the tight spaces. The KN55’s double-edged design means you can use it right or left handed. For added strength, a brass ferrule has been added and the tang extends completely through the handle. The handle is beautifully made of seasoned Cherry wood.
Blade length: 57mm, overall length: 172mm, radius variable 13mm to 32mm and double edged.
Blade Shape | Curved Edge Double Sided |
EAN Barcode | 651646500555 |
Model | KN55 |
This product is classified as a Make to Order product.
Delivery time is approximately 6 weeks.
- Standard Delivery* - Free
