The Flexcut Pro Series 1-3/8" Detail Knife has been meticulously redesigned to deliver exceptional performance. The knife features a narrowly tapered full flat grind wharn-cliffe blade in precision, heat-treated 1095 steel, polished to a brilliant mirror finish. This knife excels at precise detail carving work. The shorter blade length, slim profile, and narrower detail tip provide the highest level of precision and control
The Flexcut Pro Series range has been crafted with insights from customer feedback and professional carvers, these knives are a game-changer for any carving kit. With increased clearance between the choil and heel, you will enjoy a more consistent stropping experience, keeping blades sharper for longer.
The handles are designed with flat sidewalls, bold facets, and curves in all the right places, this premium un-varnished cherry wood handle is a joy to hold. The area under the blade has been streamlined to eliminate interference on tight cuts, and an index finger swell has been added over the spine for extra power and superior control.
