The Flexcut Pro Series 1-5/8" Carving Knife is a versatile tool designed for all-around carving work. It features a full flat grind sheepsfoot blade made from precision heat-treated 1095 steel, polished to a brilliant mirror finish. The medium blade length, slim profile, and detail tip provide enough reach for tough cuts while maintaining full control.
The Flexcut Pro Series range has been crafted with insights from customer feedback and professional carvers, these knives are a game-changer for any carving kit. With increased clearance between the choil and heel, you will enjoy a more consistent stropping experience, keeping blades sharper for longer.
The handles are designed with flat sidewalls, bold facets, and curves in all the right places, this premium un-varnished cherry wood handle is a joy to hold. The area under the blade has been streamlined to eliminate interference on tight cuts, and an index finger swell has been added over the spine for extra power and superior control.
