Flexcut Pro Series 1” Chip Carving Knife
112893
From £50.78 £42.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • Ideal for making controlled plunge cuts for many chip carving styles
  • Redesigned for exceptional performance
  • Incorporates feedback from customers and professional carvers
  • Precision heat-treated blades with true flat grind and durable tips
  • Enhanced clearance for consistent stropping and sharper blades
  • Premium un-varnished cherry wood handles with ergonomic design
  • Streamlined blade area and index finger swell for superior control
Designed for precision, crafted for comfort
Driven by user insight, the Flexcut Pro Series perfectly blends precision and comfort for an exceptional carving experience.
Flexcut Pro Series Chip Carving Knife
Innovative design
Ergonomic handle with flat sidewalls, bold facets, and curves for comfort and reduced fatigue.
Superior blade performance
True flat grind blades for ultimate performance and durability, with precise detail carving tips.
Enhanced control
Index finger swell for extra power and control, un-varnished cherry wood handle for a comfortable grip.
Customer-centric development
Designed with input from professional carvers and customer feedback.
Premium quality
High-quality materials and craftsmanship for peak performance and durability.
The Flexcut Pro Series 1" Chip Carving Knife is a high-quality tool designed for precision and control in chip carving. It features a full flat grind, deep angle chip carving blade made from precision heat-treated 1095 steel, polished to a brilliant mirror finish.
This knife excels at making controlled plunge cuts needed for many chip carving styles. The deep angle of the blade, shorter choil length, and narrow tapered detail tip provide the leverage and accuracy needed for the most detailed chip carving cuts. This knife is made in the USA. It is a valuable addition to any carving kit, offering both durability and precision for intricate carving tasks.
The Flexcut Pro Series range has been crafted with insights from customer feedback and professional carvers, these knives are a game-changer for any carving kit. With increased clearance between the choil and heel, you will enjoy a more consistent stropping experience, keeping blades sharper for longer.
The handles are designed with flat sidewalls, bold facets, and curves in all the right places, this premium un-varnished cherry wood handle is a joy to hold. The area under the blade has been streamlined to eliminate interference on tight cuts, and an index finger swell has been added over the spine for extra power and superior control.
