Flexipads Dual Foam Hand Sanding Block 70 x 125mm
- Online exclusive
- Takes Quick change hook and loop backed abrasives
- Medium foam one side for flat surfaces
- Soft foam side for sanding gently curving surfaces
This double-sided block utilises quick change hook and loop backed abrasives. A dual foam block 70 x 125mm with medium density foam one side and soft on the other side for sanding gently curving surfaces. An excellent and useful addition to the job of hand sanding and quite economical as the abrasive can be peeled off and re-used at a later date.
EAN Barcode | 5021526560057 |
Overall L x W x H | 125 mm x 70 mm x 30 mm |
- Standard Delivery* - £1.99
*UK Mainland only. Order before 3pm for Next Day Delivery. Additional charges may apply for remote or offshore areas.
