Formech 450DT Desktop Vacuum Forming Machine
- Vacuum forming machine with convenient and precise control
- Generous forming area and draw depth
- Fast warm-up facility, ready to use in seconds
- Vacuum and release controls
- Interlock ensures mould cannot be raised with heater in forward position
- Powerful quartz heaters with standby feature
- Four independent zone controls
- Vacuum gauge
Formech Universal Desktop TrolleyFrom £527.88 £439.90
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price £69.97 £58.31 was £89.98 £74.98 Save £20.01 £16.67
Formech bring the latest technology to the 450DT with a high-resolution digital PLC and touchscreen for convenient and precise control. A graphically driven display with easy-to-understand icons, provides intuitive control whilst a 20-program memory allows users to conveniently store and recall projects.
The 450DT offers today’s students, designers and inventors the latest user experience with industry standard, control technology. Key features include Mitsubishi integrated HMI-PCL with 4" mono touchscreen control and with memory function offering up to 20 programmable presets.
Quartz heaters with variable standby give the benefit of a rapid response and high efficiency resulting in time and energy savings.
Four independently controllable heating zones and quartz heaters provide rapid heat response with a greater range of control to form challenging shapes and materials.
Vacuum and release; after the formed part has cooled, air is forced between the mould and the sheet to help it release. The vacuum gauge gives a visual indication of consistent vacuum pressure being applied (pressure in Hg/bar).
EAN Barcode | 5052511106417 |
Forming Area | 430 mm x 280 mm |
Max Depth of Draw | 160 mm |
Max Material Thickness | 6 mm |
Model | 450DT |
Nett Weight | 75 kg |
Overall L x W x H | 639 mm x 986 mm x 525 mm |
Plug Fitted | UK 3 pin plug |
Supply Requirements | 230 V 1ph 13 A |
Voltage | 230 V |
Wattage | 2.3 kW |
This product is classified as an Enquiry product. Enquiry products require contact with our friendly team prior to purchase to understand your requirements. Typically these products have many customisation options or require product training.
Enquiry products are usually readily available and often despatched directly from the manufacturer using the best delivery service available. Despatch times can vary between manufacturers and delays may occur should stock become unavailable. Please contact customer services for more information.
