Formech 508FS Vacuum Forming Machine
- Highly capable vacuum forming machine
- Fitted with the very latest technologies
- Large forming area 482 x 432mm
- Draw depth up to 290mm, max material thickness 6mm
Formech’s 508FS (Floor Standing) machine includes features which offer the ability to produce complex components.
The intuitive touchscreen control makes fine tuning simple. Clear graphics and a memory function make the 508FS very easy to use. Pre-stretch avoids thinning of material with deeper tools. Auto-level avoids material sag during the heating cycle and maintains an even distance between heater and sheet. A powerful flow rate for demanding applications makes the 508FS a highly capable piece of equipment. High wattage quartz heaters further enhance the 508FS capability. With the fast warm up facility they are ready to use in minutes. Four independent zone controls provide accurate and precise heating for more demanding materials. The 508FS has a forming area of 482 x 432mm, a depth of draw of 290mm and a maximum material thickness of 6mm. The unit accepts moulds from clay, wood, resin and aluminum.
Please note, this vacuum former requires a standalone air compressor (requires 80psi/5 bar).
- Intuitive 4"touch-screen with clear graphics
- Memory function with 20 programmable presets
- Oil free vacuum pump requires minimal maintenance
