This high precision digital readout caliper has a very robust all stainless steel construction. Use for internal, external, step and depth measurements. Accuracy is 0.01mm or 0.001 and maximum measuring distance 155mm or 6. Zero can be set at any point along the range, and the display is easily switched from a metric to an imperial reading. It takes a standard SR44 battery (supplied). N.B. Philips 00 screwdriver required for battery compartment.
Batteries Includes 1 x SR44
Battery Type Silver Oxide
Measuring Range 0 mm to 155 mm
EAN Barcode 5032511069059
