Axcaliber Bearing Guided Round Nose Cutter
666043
From £17.18 £14.32
  5. Half Star
10 Reviews
  • Buy 3 for £16.32 £13.60 each
  • Buy 6 for £15.47 £12.89 each
  • Buy 10 for £14.60 £12.17 each
  • Produce round bottom grooves on doors and drawers
  • Use to make decorative flutes
  • Top bearing for following a template
  • Use with template for lettering
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps cutter to remain free of resinp
  • 1/4" shank
  • 6.35mm radius
Assurance with Axcaliber
- see how they're made
This round nose cutter has a top bearing for following a template. The bearing is the same diameter as the cutter, greatly simplifying template making. This cutter produces a round-bottom grooves in cabinet doors or on drawer fronts. It adds attractive detail such a fluting. Use a suitable template for routing recesses or lettering.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up. 6.35mm radius.
4.60 10
