Axcaliber Edge Breaker Cutters
- Exact and controlled rounding over, perfect arris removal
- Bearing guided for straight or curved edges
- Essential prior to applying paint or varnish
Axcaliber A5 Foam Router Cutter PresenterSpecial Price £4.30 £3.58 was £13.58 £11.32 Save £9.28 £7.73
Edge Breaker router cutters round over sharp edges giving a very exact and controlled result. They are available in a choice of four radii: 1mm, 1.5mm, 2mm and 2.5mm, all bearing guided for rounding straight or curved edges. These cutters remove the arris, leaving a perfect finish. If left as a sharp corner the wood may splinter or crumble. A sharp corner will not take a finish. You cannot paint a sharp edge. All cutters are 1/4" shank. PTFE coating minimises resin build-up.
D = Overall Diameter | 20.5 mm (13/16") |
