The Axminster Woodturning Chuck Soft Jaws allow you to create your own custom designed jaws. Easy to machine to shape using standard wood turning tools. A sharp, flat scraper works particularly well. These jaws are easy to use and will fit the Clubman and Evolution SK100 and Evolution SK114 chucks. Some care is required when using, but follow some simple guidelines and you will find these an excellent addition to your workholding system. Other than being able to make custom jaws, these are also non- marking making, suitable on delicate surfaces. Made in the UK from high quality glass filled nylon. As with all our dovetail jaws they simply bolt onto the Accessory Mounting Jaws.
