Axminster Professional Bed Extension for AP406WL Lathe
502704
Special Price £169.98 £141.65 was £232.38 £193.65 Save £62.40 £52.00
  5. Half Star
13 Reviews
In Stock - Ready to dispatch
  • 460mm bed extension kit includes tool rest extension post
  • Can be attached in two positions
  • Solid cast iron construction
  • Increases swing over bed to 870mm in lower position
A very worthwhile addition to the AP406WL and AT1628VS lathes, this 460mm bed extension kit will increase the capacity of your lathe in two ways. It can be bolted to the existing lathe bed for a greater between centres capacity or if you have the lathe fitted to the purpose-made leg stand, it will bolt onto the leg stand in a lower position. With the supplied tool rest extension post this enables you to turn bowls or platters up to 870mm. Heavy cast iron construction for stability and vibration damping it simply bolts onto the end of the lathe bed.
4.60 13
