From £139.98 £116.65
Low Stock
  • Stand-alone, unpowered cyclone interceptor
  • 100mm inlet/outlet, common to many machines
  • 250mm diameter flange mounting to enable easy mounting onto your waste bin
Customers Also Bought
The Axminster Workshop AWCIH is a stand-alone, unpowered cyclone dust collector/interceptor. It uses the cyclone head from the Workshop AW118CI Cyclone Dust Extractor. It is designed to be used with a standard High Volume Low Pressure chip extractor to provide enough airflow. Using this interceptor, you can create a wood dust and chip extractor which will handle even fine dusts from drum sanders. You can either use this unit to upgrade your current workshop chip extraction system (with the typical bag filter) or place this unit next to a drum or belt sander to intercept the fine dusts before the air stream reaches the chip extractor.
This is just the Cyclone body unit only, fitted with a 250mm diameter flange mounting on the bottom to allow you to use your own waste container. This gives great flexibility of choice, size and mounting position within the workshop.
It is fitted with 100mm inlet and outlets, which suits many common woodworking machines. We recommend using a High Volume Low Pressure chip extractor with at least a 1.5hp motor. It is not advised to use this interceptor with a High Pressure Low Volume (vacuum) type extractor, but if you do you must provide a vacuum release valve on your container to prevent an implosion if the inlet hose becomes blocked.
  • Works by mounting in line with your dust collector
  • Requires a dust collector of at least 1,100W (1.5hp)
  • Easy upgrade to fine dust performance of your collector
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    4.70 51
