Axminster Woodturning Multi-Head Live Revolving Centres
- Sealed dust proof bearings for long life
- Tapered working end for mounting interchangeable tips
- Supplied with three tips
Axminster Woodturning Pipe Centre for Multi-Head Live Revolving CentreFrom £6.94 £5.78
Axminster Woodturning Conical Tip for Multi-Head Live Revolving CentreFrom £4.24 £3.53
Axminster 30mm Mini Faceplate for Multi-Head Live Revolving CentreFrom £4.54 £3.78
Axminster APF 10 Evolution® Powered Respirator with Impact VisorFrom £299.98 £299.98
We believe that this is the most universal tailstock centre available today. There are two sealed dust proof bearings in the body and the working end has a taper for mounting the various interchangeable tips, guaranteeing that they run perfectly concentric. There is an ejector ring behind the tip which is operated by two tommy bars. The centre is supplied with three tips, a standard 60° cone for general work, a 9.5mm diameter by 16mm long point for small or close work and a cup or ring centre for open grain or split turning. In addition to the standard tips there are three additional tips, available separately, which will further increase the scope of the centre. We hope that you will agree that we have covered just about every possibility and that the Multi-head Centre deserves a place in your tool box. Also available as a complete package deal (718221 or 718222 ) with 3 additional tips.
