Axminster Professional AP305BDS Disc Sander - 230V
- 305mm disc sander with mechanical brake and quadrant guard
- Large cast iron table with two mitre slots at 90° to each other
- Effecive dust extraction via 63mm diameter outlet
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.18 £10.98
Safety comes first with this powerful sander.
The AP305BDS has a 305mm diameter sanding disc fitted with a quadrant guard. The large cast iron work table features two mitre fence slots to 90° to each other, giving many options for sanding end grain or adjusting mitre joints. The table tilts to 45°, with scales on the quadrant supports. Dust extraction is via a well-positioned 63mm diameter outlet.
The AP305BDS features a fail-safe electro-mechanical brake, which stops the disc rotating within 10 seconds. The brake does not require power, and works even in the event of a power failure in the workshop. This safety device is a requirement for organisations such as schools, colleges and training facilities.
The body is entirely fabricated from plate steel. Power comes from a 560W induction motor with a Euro style dust shrouded no-volt-release switch.
Supplied complete with a Hermes 305mm self-adhesive disc and mitre fence.
Axminster Professional 3 Year Guarantee
Machine Classification
Abrasive Disc Diameter | 305 mm |
Disc Speed | 1,425 rpm |
Dust Extraction Outlet | 63 mm |
EAN Barcode | 5052511124916 |
Min Extraction Airflow Required | 390 m³/hr |
Model | AP305BDS |
Nett Weight | 32 kg |
Overall L x W x H | 671 mm x 445 mm x 410 mm |
Plug Fitted | UK 3 pin plug |
Power | 560 W |
Rating | Trade/Professional |
Table Size | 400 mm x 225 mm |
Table Tilt | 0° - 45° |
Voltage | 230 V |
