Designed to be amongst the very best premium 350mm deep cutting bandsaws on the market
The 'golden' table
To attain an extremely smooth and hard wearing surface, the bandsaw table is cast iron and features a TiN (titanium nitride) coating. Not only does the gold colour make the machine look great, the smooth surface ensures effortless travel for your workpiece, whilst the hard wearing material prevents any corrosion.
Impressive 350mm depth of cut!
This bandsaw’s capacity truly sets it apart from anything else on the market at this price point. Whether you do resaw work cutting anything from large beams to floorboards or at the other end of the spectrum making fine, delicate cuts for veneering, this bandsaw can do it all.
Accurate, adjustable table tilt
The table tilt adjusts using a chrome cast iron control wheel which requires no effort to turn. Whilst this is happening the table is held steady by a rack and pinion gear and gasket. The steady, easy adjustment allows you to achieve an accurate angle for your table.
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
The Axminster Professional AP3352B Bandsaw is among the very best premium 350mm deep cutting bandsaws on the market.
The welded steel frame gives it extraordinary rigidity, allowing higher blade tensions. The machine has a 230V 2.2kW 1ph powerful, mechanically braked motor. Large cast iron band wheels give extra inertia and are balanced for smooth running. Uniquely, the precision ground cast iron table has a titanium nitride (TiN) coating, creating an ultra-hard wearing surface and protecting the table from rust.
Worm gear systems for both table tilting and blade guide post movement are used for easy adjustment. Tool-less upper and lower blade guides give you a quick and easy setting. A T-square rip fence bracket with full adjustment ensures that the fence rail is set accurately to the blade. The switch system has a brake-off setting to allow easy blade changing and setting. A locking key switch is fitted. Unusually, there is a foot brake provided, giving an additional method of quickly stopping the machine if your hands are full of timber! Door safety protection, 4-sided blade guard, quick release blade tensioning, Hi/Lo fence rail and dual 100mm dust ports are all additional features of this bandsaw.
N.B. This Machine requires a 16 amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Max depth of cut 350mm, max width of cut 360mm
Precision ground and TiN coated large cast iron table
Machine Classification
