Reduced filter maintenance with the clever, unprecedented centrifugal technology. The unique technology separates the dust from the air and drops the particles into dust containers. The air exiting the separation chambers into the filters is 99.9% dust free.
Adjust air flow to your work
The variable speed helps you tailor the air flow to suit whatever work you are doing.
Ideal for use with almost any workshop machine!
The strong, smart design makes this the ideal companion for your table saw. Unlike similar models the outlet adaptor that comes with the machine as standard will fit a dust hose for the Crown guard and provides a high suction level to draw air down a small diameter hose.
Very low noise level
The very low noise level typically 61-76 dB(A) allows this high performance machine to be used in any busy workshop and especially reliable for educational use on woodworking machines.
3 Year Guarantee
For complete peace of mind, we cover all parts and labour free of charge for three years.
The Axminster APG700DP Gyro Air is a different kind of dust extractor, designed for extracting wood dust". Traditional cyclone dust extractors separate wood dust from the air stream by gravity. They need a bin for large particles, a bag for fine dust and the filters require regular cleaning in order to maintain performance.
The APG700DP Gyro Air spins the debris-laden air at approximately 4,000rpm within twin stainless steel double cone separation chambers. The centrifugal force pushes the dust particles out from the airstream into the dust containers. The air stream exiting the separation chambers is 99.9% free of waste dust as it passes through the filters. In actual fact, the filters have very little to do. The technology does not stop there; a V20 inverter controls the motor speed. Regulating the speed adjusts the airflow to tailor it to suit a particular application.
The overall design is compact and mobile; making it easy to move the extractor from job to job. The waste collection bins are easy to empty, cleverly coming out on rails from inside the machine.
The APG700DP Gyro Air offers new waste management technology for the modern workshop.
99.9% wood dust separation efficiency before filtration
Very low noise, compact and mobile
Strong and constant static pressure, highly efficient waste collection
Machine Classification
