Axminster Professional Double Edge Clamp
- Increase the versatility of F clamps, solution for clamping lipping or edging
- Double screw spreads the load over an area
- For use with any F or bar clamps with rails up to 6.5mm thick
See the entire rangeThis Double Edge Clamp increases the versatility of your Axminster Professional F clamps or forged flat bar clamps plus any other similar clamp with a 6.5 mm or less thickness of bar. Adding this twin-screw accessory to an F clamp bar is a great way to attach edge banding, framing and decorative parts. It allows you to apply pressure exactly where needed. The Axminster Professional Double Edge Clamp turns a humble F clamp into a very effective edging clamp. The body is solid steel machined round bar 100 mm long and 25 mm diameter, strong and unbreakable. It features wooden handles fitted to cleanly formed Acme screw threads; applying pressure is quick and easy. The spindles are 65 mm apart centre to centre giving a good spread; the reach is 50mm. The 25 mm diameter clamp pads are on traditional swivelling mounts to take up any slight variation and feature non-marring glue resistant caps.
EAN Barcode | 5052511073610 |
