Axminster Professional Parallel Jaw Clamp
From £12.52 £10.43 was £18.68 £15.57 Save £6.16 £5.13
  5. Half Star
142 Reviews
  • 200kg max clamping pressure, jaws remain parallel under pressure
  • Polyamide, glue resistant casing surrounds the jaws
  • Reversible head so cramp can be used as a spreader
See the entire range
The Axminster Professional Parallel Jaw Clamp will find favour in situations where heavy-duty clamps are too weighty and cumbersome. The clamps exert sufficient force holding your work firmly whilst glue cures. The large surface area of the jaws spreads the pressure evenly. A polyamide, glue resistant casing surrounds the jaws. The jaw faces remain parallel across the full width of the clamping area. The heads are reversible so the clamp can also act as a spreader. These are excellent, convenient cramps for light to medium duty applications. 200kg max clamping pressure.
Lifetime guarantee.
Warranty Axminster Professional Clamps Lifetime Guarantee
4.60 142
