Axminster Professional T Slot Clamp Set & Cutter
720776
From £39.98 £33.32
1 Review
In Stock - Ready to dispatch
  • Cut a T-slot in a workbench or an assembly table
  • Use of guide rail clamps as hold-downs
  • Cut a T-Slots in for home-made jigs and rails
Use the cutter to produce a T-slot in a workbench or an assembly table. Once cut the T-slot enables you to use the Axminster Professional guide rail clamp as a hold down. The clamp has a specially designed head that fits into the slot of power tool guide rails such as the Festool FS, Makita and Aldi Workzone rails (not suitable for Bosch). Alternatively cut a T-slot in a length of hardwood as a custom made or temporary guide rail. In addition, you can cut a T-Slot in nylon if making jigs to your own design.
The clamp has a plastic pad on the swivel shoe to protect the work surface. It doubles as a hold-down when inserted into a 20mm dog hole of a multifunction workbench.The spigot is 11mm wide by 7.5mm thick and 60 mm long. 160mm capacity. Cutter 1/2" shank. Supplied with 2 x Axminster Professional Guide Rail Clamps (106 X 60mm).
4.00 1
