Axminster Workshop Sawhorses (Pair)
- Use to create a strong worktable anywhere on site, supplied as a pair
- Immensely strong, 590kg support capacity per trestle
- Fold neatly for transport and storage, easy carry handles
- Quick and easy to set up
- Independently adjustable telescopic legs, non-marking feet
- Powder coated and zinc plated for long life
These all-steel, folding sawhorses are immensely strong, durable and highly portable. Constructed of high-grade steel, each sawhorse can support a weight of 590kg; a pair has a capacity of 1,180kg.
With their fast-open mechanism, setup is straightforward and simple. Unfolding the sawhorse reveals a material support arm at each end, designed to take 95mm high timber. Alternatively, you can trim your timber to the required size. With two sawhorses, a couple of lengths of trimmed 42 x 95mm timber and a suitable sheet of ply or OSB, you can create an instant, rock solid site worktable.
The sawhorse legs are telescopic, allowing you to adjust each one individually to compensate any unevenness on the ground. Powder coating and zinc plating protect the sawhorses from corrosion and ensures a long life in a working environment. The legs fold neatly sequentially into the top rail, forming an 84 x 150 x 895mm long package, which is easily stowed in the back of a van. The legs are fitted with non-marking feet. The sawhorses include a carry handle for easy transportation and rolled edges mean there are no sharp corners.
Sawhorse length when open: 1,070mm, minimum height: 648mm (width 464mm), maximum height: 826mm (width 622mm).
EAN Barcode | 5052511092826 |
