Axminster Woodturning Discovery GK88 Chuck Package
From £174.98 £145.82
3 Reviews
  • Perfect for anyone looking to start woodturning
  • 88mm chuck diameter
  • Features an interchangeable backplate, useful for if you change your lathe
  • Stainless steel body and backplate for effective corrosion resistance
  • Geared chuck
  • Made entirely in Axminster, UK
  • CNC precision engineered for accuracy
  • 5-year guarantee
Axminster Discovery Chucks
Made in Axminster, UK, our Axminster Woodturning Discovery chuck range is the latest development in our chuck offering. They are a true example of our consistent efforts to ensure we continually develop and produce innovative tools for the woodturner.
The Discovery range is designed to be versatile, with interchangeable backplates so you can keep hold of your chuck body should you wish to upgrade your lathe. Super versatile, incredibly accurate and ideal to begin your woodturning journey with.
Read more...
Buy with confidence
The Axminster 5 year guarantee is available on Discovery GK88, GK100 and SK100 chucks, provided the chuck has been properly maintained.
Find out more
Made in Axminster
Designed, developed and manufactured entirely in our state-of-the-art manufacturing facility in Axminster. This gives us complete control in ensuring the chucks we produce are supreme in terms of quality, accuracy and longevity.
Stainless steel & super precision as standard
We are mindful that chucks can corrode so stainless steel is the perfect choice of material for the chuck. The Discovery GK88 chuck is machined to tolerance for a perfect fit of both jaws and the lathe mandrel.
What's in the box?
  • Discovery GK88 Chuck
  • Interchangeable backplate
  • Dovetail Jaws – Type E
  • Accessory Mounting Jaws
  • Faceplate Ring
  • Screw Chuck
  • Chuck key
Choose your chuck
E dovetail jaws
Perfect for anyone new to woodturning, Dovetail Jaws are the most universal jaw; the design provides a strong, reliable grip on the workpiece and they are ideal for holding a variety of workpieces of different shapes and sizes.
Faceplate ring
A faceplate ring enables you to easily mount bowl blanks, platters and the like to ensure a firm grip of your blank whilst you turn. Simply screw the ring to the chosen blank with woodscrews and expand the dovetail jaws into the recess in the centre of the ring.
Screw chuck
The screw chuck is compatible with the Dovetail Jaws Type E. Using a screw chuck is a quick and convenient method for mounting a turning blank on your lathe. The central screw has a deep sharp thread for a positive and secure hold.
With versatility in mind, the stainless steel, interchangeable backplate allows you to keep your chuck body and swap your backplate should you wish to upgrade your lathe and need a different thread size.
Reverse locking is available on the M33 x 3.5mm backplate. This unique, universal thread combines the standard M33 x 3.5mm thread, allows users to add the ASR Locking Ring, as well as grub screws to turn in reverse, all in one thread. It is suitable for lathes with a M33 x 3.5mm Euro standard ASR spindle.
Geared chuck key
Hardened pinions ensure the chuck is always accessible, from any angle, to tighten with the key. The key has special grips to avoid slippage and has a warm tactile feel. It is always good practice to tighten all pinions when securing a large piece of work on the lathe.
Finely machined SafetyJaw
Manufactured in our own machine shop in Axminster, these long accessory mounting jaws are unrivalled for quality and precision. We like to call them SafetyJaws because a unique feature of these jaws is that if extended beyond the body of the chuck, the edges have been modified with a slight radius to minimise the chance of injury should hands get too close to the rotating chuck during use. Added safety features also help to ensure the jaws are correctly mounted safely to the chuck.
Axminster 5 Year Chuck Guarantee
The Axminster 5 year guarantee is available on Axminster Woodturning Discovery Chucks.
Together with Axminster's 3 Year Guarantee on Machinery, it's probably the most comprehensive free guarantee ever - buy with confidence from Axminster! So sure are we of the quality, we cover all parts and labour free of charge for five years!
History
Back in 1984 we produced our very first woodturner's chuck having thought long and hard about what would be an ideal chuck for a woodturning lathe. As engineers, we automatically preferred a scroll chuck and as three jaws were totally out of the question for woodturners (cutting triangular stock is just not that easy), the four jaw chuck system was born.
It wasn't long before we explored all manner of different accessories for the chuck as engineering style jaws were a little limited if not dangerous. We devised a style of mounting four quadrants of a profiled disc that we called jaws, these jaws are still to this day compatible with all the chucks we have made. It is important to us to ensure that the accessories you purchased yesterday will still work with the chucks we make and sell today.
Something we never anticipated was that our chucks would be copied so much and that the market would be so large. Our design was based around interchangeable sets of jaws where the accessory jaws were interchangeable from set to set, whereas other makers relied upon just the one set of jaws, changing eight screws every time you change the profiled quadrants.
Advice from our experts
Read our Buying Guides or contact us to find out more
The Axminster Woodturning Discovery GK88 Chuck Package if the perfect introduction for anyone looking to start woodturning. Encompassing all the basic tools necessary for work holding on the lathe, the package includes an Axminster Woodturning Discovery GK88 Chuck, Dovetail Jaws - Type E, Faceplate Ring, Screw Chuck, Chuck Key and Interchangeable Backplate.
The chuck, jaws and accessories are all precision engineered and made entirely in Axminster, UK, to ensure they deliver CNC accurate results. The GK88 chuck features a geared key, stainless-steel body and interchangeable backplate for effective corrosion resistance. These chucks won’t rust, either from condensation in a cold workshop or the sap from green wood. Stainless steel body is machined to exact tolerances for a perfect fit of both jaws and lathe spindle.
The interchangeable backplate allows you to keep your chuck body when upgrading your lathe, saving you time and money; simply choose the suitable backplate for your new lathe thread and attach to the chuck body. Upon first purchase of your chuck, choose the correct thread for your lathe.
The GK88 Discovery chuck is the smallest in the range; its light and compact size makes it ideal for a variety of lathe models but ideally more suited to small to medium sized lathes. The Dovetail Jaws give a stable and secure hold of your workpiece with both an internal and external grip. Supplied is also a Faceplate Ring to use for mounting bowl blanks onto the chuck before initial turning and a 'one piece' screw chuck; designed to bite into the workpiece, perfect for holding smaller projects.
The GK88 chuck features our latest SafetyJaw accessory mounting jaws. Pair the chuck with our great range of 88mm jaws to suit your project needs.
Available in sizes 1” x 8 tpi, 1.1/4” x 8 tpi, 3/4" x 16 tpi and M33 x 3.5mm. The M33 x 3.5mm thread is a universal thread, that combines the standard M33 x 3.5mm thread, allows you to add an ASR Locking Ring as well as grub screws to turn in reverse, all in one thread. Suitable for standard M33 x 3.5mm threads and lathes with an ASR spindle for running in reverse. If want to run in reverse, you require a lathe with an M33 x 3.5mm EURO standard (ASR) spindle and the 109370 ASR Locking Ring (sold separately).
If you're looking to take up woodturning, then this kit is the perfect starting point. Providing you with all the tools you need to start working on the lathe and exploring this captivating and creative hobby.
All made entirely in our manufacturing facility, in Axminster, UK using CNC technology for accurate results.
To ensure the chuck is assembled safely, secure the chuck front to the chuck backplate (threaded insert) using the 4 x M6 x 25mm screws and ensure they are tightened to 12NM (Newton-Metres). Please ensure the 2 x M5 Grub Screws are tightened to 2NM.
Warranty Axminster Woodturning Chuck 5 Year Guarantee
The Axminster Woodturning Chuck 5 Year Guarantee is available on Axminster Woodturning Clubman SK100 and Essential SK88 chucks. We're so confident in the manufactured quality of our chucks that, in the unlikely event a fault should occur, we cover all parts and labour free of charge for five years!
It's probably the most comprehensive free guarantee ever - buy with confidence from Axminster.
Find out more
British Made British Made
5.00 3
