Axminster Woodturning Diameter & Thickness Calipers - (Pkt 2)
New
From £54.98 £45.82
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Available in large or small to cover most measuring situations
  • Each set contains one double ended pair and an inside/outside pair
  • Made from stainless steel, in the UK
Two sets of turner's calipers, large or small, covering most measuring situations. Each set contains one double ended pair for measuring wall thicknesses (type 1) and an inside/outside pair for checking diameters (type 2). In both cases, the two ends of the calipers produce the same setting, allowing measurements to be made without removing the calipers from the work. If you are working with wet timber, these calipers are perfect as they are stainless steel, therefore corrosion resistant.
Capacities are:
Small set - type 1: 120mm, type 2: 190mm.
Large set - type 1: 220mm, type 2: 260mm.
These calipers are made in Axminster, UK.
British Made British Made
