Axminster Woodturning Micro Handles combined with the range of miniature turning tool blades are perfect for turning pens and other small projects. The six different colours allow you to colour code your tools for easy recognition. Axminster Woodturning Micro Handles are another fine example of precision engineering from our own manufacturing facility in Axminster. Machined from a solid aluminium they have a hard anodised finish. Their gently contoured grips with light knurling prevent them slipping in your hand.
Designed to accept a range of small and miniature turning tools the handles have a 7.5mm bore with twin grub screws to secure the blades in place.
Size 150mm long x 25mm diameter with 7.5mm bore.
Anodised aluminium handles for small turning tool blades
7.5mm bore, blades lock securely with two grub screws
6 different colours for quick and easy tool recognition
